FAO Gonzo12c
Hi bud,
I remember in one of your previous threads you had moved your fuse box down to void left by the air con pump.
Got any hints and tips on this? I had a go at this at the weekend and it was a pain in the ass lol. It wouldnt fit in the area below the headlight panel because of the power steering pipe (i suppose i could replace this with silicone?) and i couldnt figure out how to fit it in the space left by the air con pump. Mainly because of it awkward shape.
Did you have to do any drilling to bolt it in?
Not back in the UK till next week so i cant get any close up pics but the fuse box can be spun around and mounted on one of the bolt holes in that area. I havent mounted the other fuse box hole to anything so far.
unplug the 2/3 plugs too by the fuse box to reroute and get the movement but no cutting of wires needed. These 2/3 then can mount down by the engine mount. Oil pressure sensor wiring needs unclipping and rerouting.
i re-routed things like Maf wiring too as the whole thing was apart just slightly though. I can take some pics next week anyway so you can see orientation and where its mounted to but this is both my zeds that i have done it on below and you can see all the wires are tucked away.
