Revs drop right down at 4000rpm?
My ZX is running much better after changing the maf and two o2 sensors. The only problem is when I step on it, around 4000rpm it will drop right down as if there is no gas. I then depress the pedal and she drives fine, as if I am driving a manual car. The engineer could not find a fault when he connected the ZX to his diagnostics device. He said maybe the spark plugs need changing.
Any ideas?
Not revving past 4k revs sounds just like MAF, i know you have changed it recently, did you get a new one or second hand one? also, is it plugged in? though would of thought it might be a bit rough
Mine ran OK with the the maf unplugged when I took it over to Zedworld,
Could not go past 2,500rpm though.
I have a new one fitted, starts and drives like a dream but just cuts out around 4000rpm. It's not an original one, aftermarket maf. Do you think this is why it is cutting out? I was told to tune the engine once the maf was installed. What part and how will it be tuned?
  • 3 months later...
Update for the rpm symptoms.
The revs will go all the way now but when I reach full boost the throttle cuts off and then I need to move my foot of the pedal and depress to accelerate. The problem started to happen after my car come out of the garage. I had two 02 sensors and a maf fitted.
Any ideas?
If the afm is a non genuine one like the ones on Ebay for £60 to £70 ( Below) then that is a very likely suspect, the non genuine one`s are notorious for poor running, cannot see how or why these companies exist selling naff stuff?
Jeff TT
Item number: 330657944477 £49.99 free p/p ???? too cheap!! blatant copy ( bad one too)
Edited by JeffTT
