all been going smooth untill tonight
to what i have been told the NA Rear half of the drive shaft should Mate up with the Front half of the TT Shaft
it dose not they are completely diffrent in size
am i doing some thing wrong ..
pic below shows rear tt half with front na so u can see size/hole diffrents
looks like you may have to use the full shaft from iether the n/a or the tt coz any way you look at it thats not mating up
looks like i will have to fit the complete drive shaft set ...
acording to the pdf the Na gear box and TT have the same output spline shafts
turn the na prop round that flange supposed to bolt to the diff
there both the same size but all so it was all ready bolted to diff
funds permitting you could get a one piece
lighter n you dont need to worry bout the bearing failing
the difference should only be at the diff end. 6 bolt fixing on the tt and 4 bolt on the na
sorry i edited my post as i wasnt looking at the pic properly!
Remove the more square flange from the front half if the TT prop and replace it with the round flange from the front of the n/a prop, easy enough just undo the 27mm nut and then tap it off, and refit accordingly you will end up with two matching round flanges on a sort of hybrid prop, this works because the flanges have the same internal spline count and size where they fit on the shaft.
The only issue you may come across is balance issue as they are not a matched pair, you might be lucky and its ok.
Jeff
should really stop drinking beer during the week LOL
lol +1...but i knew what he was getting at..kinda..sorta
cheers for the Help Lads .. all done and fitted now
ended up fitting the complete NA drive shaft
Sub frame Locking spacers
Upper Ajusting arms
and a good clean and lick of paint
