Manual gear Box loom ?
Hi does anyone have pictures of what loom should connect to the manual gearbox. I got few plugs near driver side headlight. So what should i plug? I think that loom ate connecting to alternator as well.
I think picture with all the looms will help me a lot.
You can use and are probably better off using the auto loom, if you are doing the manual conversion. You will only need to splice in the reverse lights, which is in the grey plug behind the headlight. No other part of those plugs are required. The speed sensor plug is the same for auto and manual and dont bother with the neutral switch.
Thanks guys is was really helpful
