LED polarity...
Which is the + for the bulb for the lights switch? Mine has been attempted at LEDing before, and I think they were an alcoholic with the shakes, any markings have been melted off, and can't find it in the FAQ....
Cheers, Tudor.
Thanks mate, but I meant which is positive and negative on the actual PCB, ooh, also on the wiper knob too...
There are two positive take-offs on the PCB and one ground. The positives are both marked with ill+ somewhere in the track, the negative is just marked 'ill'. Are there absolutely no markings whatsoever?
Well, I want to solder in a led and resistor to the tracks where the bulb holder would normally use, but I don't know which one is positive, and can't ring it through as I'm not with the car, and it is a separate unit on both pods so I can't ring it through on the pod, if that makes sense :) Need to know for the bulb for the light switch illumination, and the bulb for the wiper switch illumination, done all the rest...
so this is in the pods, not the cluster? Sorry I misunderstood. Groover will be the best one to ask, I haven't done the pods ours were already LED'd quite well when we got the car they were in.
Yeah they are mate, but I just did it the old fashioned way, as I'm tight :) Sorted now, Groover got in touch...
