Autodata With Nissan 300zx
some of you may know autodata program, its brilliant!!!!, any problems any car all sorts on it! anyway ive found this on it, is it true?
[ATTACH]62326[/ATTACH]
[attach]62327[/attach]
[attach]62328[/attach]
I have autodata lol, but only clear the codes if you fixed the problem, or they will come back again. I use datascan to erase my codes, if i had any.
Edited by groover
Yep, that works. Standard method for fault code check.
there`s a switch on the ecu to do it
not all cars have this for some reason - my UK '93 model does not!
I used to short the pins out to read the codes before I had datascan
You can also put it into "mode 2" which checks the O2 sensors as well!
It's how they used to do it. It's much quicker than removing the footwell board and carpets.
