Well after a bit searching and bleeding the system i have discovered that the UJ that goes on to the rack seems to be my fault and is giving me hard steering. I have wd40 up the joint and at the mo all seems well
My question is, is that all i need to do or will it go back to the way it was and i need to replace it? hope that makes sense.
It should be alright if that was the problem, give it a spray whilst someone else turns it left to right to get all the bits of the joint done. Oil or grease might be a more long term solution than WD but I'm sure someone with a bit more nouse will answer shortly
Done mine about 4 years ago & it has been fine - even being off the road & not used for 2 years inbetween LOL!!
Checked it a while back & no play, seizing or roughness at all!
ok cool hopefully it be ok then. there is no play in it but it was just hard to turn.
