prop size confusion question
took out a prop from a auto tt lwb today,
we have a manual tt swb prop that came with the conversion, now from what i have been reading the rear section is the bit that is different in size but when we put them next to each other the rear prop sections are the same length???
obviously the front half is different size but the original auto one is shorter....
will it fit?
thank you , so according to that there is no difference between swb and lwb if they are both tt manuals?
we have a manual tt swb prop that came with the conversion, we put them next to each other the rear prop sections are the same length???
The clue to your question is here, what you have been sold as a swb prop clearly is not if the rear section is the same length as a lwb one.
Jeff TT
Jeff TT
That's perfect then thank you :-)
Your welcome, can help with swb manual one if required
Jeff TT
