wipers at it again
has anyone come up with a solution for the non stop wipers yet thought id fixed mine been ok for 3mths now started again changed motor white box and switch but to no avail its really annoying i know taking the white box out will stop the prob but there must be a permanent solution somewhere
I would imagine that there is a relay involved somewhere in the circuit, maybe it is sticking?
or even the connector to the relay itself has corrosion causing a short.
maybe could it be the amplifier on the drivers inner bulkhead altough ive changed that as well but not this time or could it be moisture somhwere even on the washer bottle connections on the inner wing as i say am at a loose end now especially when i thought id fixed it and its lasted 3 mths
I had a not to dissimilar problem, turned out to be the brown relay under the drivers wheel arch that had badly corroded. ended up re working the connector block with all new brass connectors and a new relay.
cheers is it the front of the wheel arch where the washer bottle is or at the rear of the wheel arch behind the liner.
Rear of the front wheel arch behind the liner, (Brown in colour) with black shroud if memory serves me right.
cheers for that will check it out its the only bit ive not changed can u get the relays easy enough
