May 31, 200224 yr Can anyone advise me where to get a turbo repair kit, for a good price on the internet?
May 31, 200224 yr what has happened to the turbo? And there is more to just repairing it, youll need to get it balanced ect when you have changed any new parts.
May 31, 200224 yr Well there's white smoke coming out the exhaust on the left hand side when the car is warming up and the mechanic told me it was a turbo going bad (u think this is true?) anyway he hasn't got a turbo repair kit so he told me to get one!!! oh yeah by the way I have a 94' TT manual 2+0
May 31, 200224 yr well its an engine out job really to get it sorted. You can do it with engine in but i think it is easier to pull the motor. Also a good excuse to get things checked out in the background. Sounds like turbo, but could be some other things.
May 31, 200224 yr No one i could recommend really but try Jim wolf tech, i think they are a very safe bet for replacment turbos ect. Where are you in the world?
May 31, 200224 yr Do you know North Cyprus? The divided country. I live on the north side(turkish side). Not many zx's in our country, we have 3 tt's including mine and one N/A, so no one really knows about the Z engine and how to maintain it, I'm having a really hard time looking after it but I can say I have the best Z in my country!
June 1, 200224 yr You can replace the oils seals on the turbo relatively easily. though you need to be aware that the one of the nuts holding the impellas on is usually a left hand thread, and snaps the shaft easily. However the seals do not go for no reason!! they usually go because the bearings are worn allowing excess shaft movement. The bearings usually go because of lack of lubrication. Lack of lubrication is usually because the oil feed within the turbo is blocked (usually burnt oil residue from insuffucient cool down time after on boost running. (Your exhaust gas is at about 700 degrees culcius - the turbo temperature is controlled by water and oil passing through them - if you switch off and stop the flow it just boils away..) You will certainly upset the balence of the turbo by dismantling it and reassembling it. Out of balence will also result in rapid failure of the bearings / seals. Very rapid, given that you can expect speeds in excess of 100,000rpm with these little turbos / high boost. If you don't mind some advice - Take the offending unit off and ship it to a specialist turbo overhauler for reconditioning. they will do the same job as your mechanic, except that they will replace the impeller nut(s) and balence it. Unless the unit has been abused to death I've never had to spend more than £300 for this even on some very rare motors. I've got a contact in my book at the office in Essex / England who will work mail order if you need it. Just reply here and I'll sort it out for you... Bon Chance.
June 1, 200224 yr Oh. You may also want to clean / replace the oil feed and return pipes when you put it back on!!
June 1, 200224 yr Cheers mate, The thing is I've got money problems and my mechanic told me he would do it for £150 (not bad), but the question is can he do it properly. I don't really care about the money when my Z is involved but when I haven't got any thats a differn't problem! Is it really hard to balance the turbos, because the mechanics in my country are useless. If I asked him if he could balance the turbos he would say yes but how could I understand if he could or not? is there a way to understand? pls help me cause I don't know abut balancing turbos! Thanx in advance
