Fuel Pump ECU Modulator Control
Just after some more information on the above. My fuel pump at the minute just pumps constantly without varying speed, (although it sometimes struggles when the revs are hunting really bad). I think I remember Jeff saying it was because the fuel pump ecu will have been shorted out due to it not working.
So am i right in saying that if I buy another one (such as the one black magic is selling) and then replace mine the fuel pump will run normally and I'd get rid of the constant whining noise????
Anybody fitted one of these? because i wouldn't even know where it goes.
As always any help is greatly appreciated.
Yeap should fix it by the sounds of it, they are designed to only step up speed when you come on boost for the exact reason of not whining like mad in the low revs, nissan did build the unit to revert to high speed upon failing of it's ecu to be a fail safe against under fuelling.
To my memory in a 2+2 is under the panels on the sides of the rear seat, easier to whip out your rear seats to get the cover off and get easy access to the unit, it is on the left hand side when sitting in the car from my memory, as the ABS control is on the other. i can't be certain which side though, it has been a while.
Hope that helps somewhat.
Mark.
excellent, cheers bud that is awsome. Don't suppose you know if it is just plug in and play or weather there's any soldering or splitting wires?
I've unplugged them when parting cars just unplug the old one and plug in the new one.
