HICAS Diagnostic
The instructions to put the HICAS in diagnostic mode specify putting the car in neutral, is this just to prevent the wheels from turning, or is it needed for the diagnostic procedure? The reason I ask, is I didn't connect up the neutral switch when I did my manual conversion, I just adjusted the timing accordingly...
The ecu knows when the cars in neutral via the switch,no switch no hicas diagnostics im afraid unless you find a way to ground pin 44 intermittently to enter hicas hicas diagnostic mode.
Edited by jimmer
