Slight misfire
Hi guys,
Hopefully someone can shed some light on this. Driving along the motorway last week and everything is running nice, then while in 5th gear and relatively slow speed (50ish) I start accelerating and hear a slight pop and a little miss!
It only happen once and then everything goes back to nice.
It then happened again this week. Exactly the same situation, only at slow speed in top gear and trying to accelerate, then back to normal.
I should probably have changed down, but it has never happened before and doesnt happen in any other gears :sad:
I have checked obvious things like leads connected etc.
Could a sensor of some sort be on its way out?
Ben
Its now developed into rough running at idle!
Still revs ok but not smooth.
Does anyone have an idea of what to look for first!
check all your PTU, coil and injector plugs for green/white gunk
this would give u missfires if corroded
Mark
Power Transistor Unit
its the item that sits on the front left of the cam cover
May be silver ( S1 ) black ( s2 )
as above injector plugs and injectors, coil plugs and coils, ptu connections etc etc.. If you find all these are good then if you have a leak tester then get some smoke bombs and check for any air leaks. Also check your PCV pipes in you rocker covers have not started to come lose. the one near the battery seems to be common fault
Also check your temp sensor plug on the front water pipes, if its corroded can be part of the cause of rough idle.
Thanks I will start checking connections. Probably not a coincidence that this has happened at the same time the damp weather came along!
Well I have spent the whole morning leaning into the negine bay, disconnecting any electrical plug I could find and cleaning them up. Some had the green gunk in but not anymore!
Problem is the rough running is still happening.
Could the PTU be failing?
Is there any way of testing the PTU or MAF if you dont have spares?
BenB........ I work at Stansted Airport, and can come over to give you a helping hand if you want. Let me know buddy...... My email addy is: alan.goulding@hotmail.co.uk
Alz.
Is it not the old school test of spraying carb cleaner around the hoses and if the engine dies you have found the vac leak? it used to work on american stuff I have owned in the past,
