ecu chip removal
No, just a soldering iron, a solder sucker and some patience.
can someone post a pic of a socketed ecu as im not sure about mine
Edited by spritley56
they do sell them... but you can remove it yourself..
the trick is to pry it out slowly and evenly.. without damaging anything else as well.
this is a cheap type one....
images?q=tbn:ANd9GcSwYtm4cPmw6XaZqBoGHDdciMB6JYdIs4vEtmFrVm4CvtOrmPS6Xw
You remove the old chip, replace it with a socket and then you can swap chips over easily in the future.
hey Andy I think he has to determine if he has or hasn't a socked chip before he attacks it with blow torch...lol...
unless you know that it isn't... :)
This is want you want ideally, iron and sucker combine, the tip is hollow, goes over the pin, melts the solder, the you just suck, job done, does a perfect job every time...
http://www.ebay.co.uk/itm/30W-IRON-Electric-Iron-DESOLDERING-PUMP-SOLDER-SUCKER-/170486044619?pt=UK_Home_Garden_PowerTools_SM&hash=item27b1c297cb#ht_3746wt_1185
I've done dozens and dozens of these, all the hard way with a separate solder sucker - I wish I'd known that these were available - gonna have to get one now ...
As long as your very careful you can use a small flat blade screwdriver to prize the chip off. I'd also recommend an antistatic wrist band just to be on the safe side, static can fry a chip instantly.
EDIT: ONLY works on a socketed chip not a soldered one!
Edited by Steams
No, it's the same, for PLCC type devices. If you're going to buy one then get one of the simple looking ones that I showed earlier - they do work.
