protoj ·
Hi All,
Not sure where to put this really.
We had been asked by a member of your club to hold a day a week 2moz, Sunday 9th October to hold a Rolling road day fro your club.
Our business is called Dynodaze Ltd and we are based in the midlands. Hinckley Leicestershire.
Problem is we havent really heard anything from you guys and have not had a cancellation either.
Whoever booked it also had something to do with a club called talkford. I hope that helps jog someones memory.
As the day is fairly close by we dont have much choice but to roll with it.
So please fee free to drop in and have x3 runs on the rollers for just £30!!
if you need any more info please drop me a text 07775646509.
all the best
Danny Dynodaze aka Kenobi
