- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi folks. My car has developed a really bad idle. i couldnt adjust it with the aac valve adjusting screw so fitted with a new iacv unit. still lumpy. ive checked all connectors and the one going to the ficd solenoid is only gettin a feed from ground side. ive traced it back to the ecu where its sending the feed and tried a known working ecu too which hasnt helped. it might be a broken wire somewhere in the loom. so ill need to try that. but also when i did a leak test there was a slight leak in the plenum. so my question is this, would the ficd cause the revs to bounce on idle and almost cut out or could it be the air leak causing this. it seems to be getting worse. before it was fine when driving but now its not driving right either.
Also is there anyone in the glasgow area who has a consult that could check it for me?
Thanks in advance
