Electrical Schematic
help please i need the electrical schematic which shows the wiring in detail to my ORIGINAL dashboard cluster . my nissan is a 93 series 2 ( i think) tt automatic with the cruise , abs , Hicas etc etc lights originally bulit into the instrument clocks not seperate on the binnacle as more commonly seen. i am now going to retrofit an earlier binnacle to go with the modified cluster in order to maintain the ancilliary lights .
can anyone point me in the right direction please
thanks
Neil
~Groover it does not appear to cover my instrument cluster set up, my setup originally incorporated all ancilliary lights for Hicas, Power, Hold, etc into the instrument cluster, this was done via two ear type connections which clipped onto the top of the cluster, the wiring in this loom is different to the standard which is why i need the correct diagram in order to figure out how i need to hard wire / modify accordingly
yes i am indeeed, Jaikai can you drop me a line please, i could do with your comments on how you modified the wiring
thanks
