CD Autochanger
In my jap spec 91 TT there's a CD Autochanger I was wondering if anybody could tell me if it was standard and if they know anywhere I can found out what the error message mean. It loads the CD then won't play it and the head unit reads E-04, then tries the next CD. The head unit is just a small controller in the central console box, between driver and passenger.
The cd model number is Sony CDX 5N51W and is a 10 disk autochanger.
Cheers,
Rich
Check the CD's are the right way up!
Matty.
Done that, first the correct way then the incorrect way to be sure!!!
Tried different types of CDs aswell, ie. normal and CDR.
Yello Tricki, just seen your posting and pulled out my handbook. Still got the documentation with the standard Jap CD unit fitted in mine, same model number anyway....... sadly it all in japaneeZe. It does mention E-4 but i can't figure it out!!! However, the next paragraph shows a diagram of a reset button being pressed on the CD changer unit, on a box attached to the side of the main body. If i bump into any JapaneeZe tourists over the weekend i"ll ask for a translation, but i think the reset button may do it. There are only 4 error codes listed....E-01,E-02,E-04 & E-99. Hope this is of some help? smile.gif
is there an echo, echo, echo in here!
Sadly no luck with the old reset button.
Thanks for the help anyway.
Any other ideas will be much appreciated.
