play in steering wheel
hi new to the zeds and mine has alot of play in the steering wheel. when you pull it it has some forward travel and some play pulling it left and right.
I have checked where it bolts on and all i can see is the two triangle blocks that attach the steering wheel to the console.
is it spose to be like this?
cant find a good picture or diagram of how its ment to be (even on the online manual)
:huh:
The triangle brackets you can see are where the issue is, originally they would have had 3 pips of plastic locating them against the colomm these pullaway eventually usually due to the stering wheel been pulled sideways when exiting the car.
You will find the nuts still tight so can be confusing why there is movements, what you can do however is loosen the securing nuts and turn the triangle bits sideways to secure the colomm more, not an exact fix but will improve things, if your unsure what I mean I will post some pics for you tomorrow.
Jeff TT
thanks mate, was worring id rip the steering out. will try turning the triangles, but a picture would be great.
cheers
I have exactly the same problem, cheers Jeff, it is a bit confusing as you said, as the nuts are tight...
