Measuring wheel bore
What would you guys use to measure the centre bore on an alloy wheel? The other halfs' wheels need spigot rings but I need to work out what ones will fit :stupid:
It's a Pug 207 and it's 17" Wolfrace wheels if that's any help lol
I believe most wolfrace are 72.6, a tape measure (used from the 100mm mark not the end ;)) should be enough to establish if thats correct, or if you feel flash these look a bargain: http://www.ebay.co.uk/itm/6Inch-150mm-Digital-LCD-Caliper-Micrometer-Vernier-Tool-/280730322189?pt=UK_Measuring_Tools_Levels&hash=item415cd4c50d
I haven't used that supplier so cant comment on them, just thought it was a good price !
These should be right if the above is correct http://www.ebay.co.uk/itm/4-72-6-OUTER-SPIGOT-RINGS-PEUGEOT-207-/180514568834?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item2a0781ba82
Again, I haven't used these either ! I got mine from spigotringsrus on ebay, but they don't appear to do Pug fitting.
Obviously double check first, I am not accountable for any errors :p :D
Edited by Bartflaster
A quick google search shows the Pug centre bore to be 65.1mm and it looks like wolfrace use a 72.6 bore size.
The wolfrace website sells plastic spigot rings, you have to give your car make and model, so they should fit if you order from them.
I bought a set of alloy spigot rings from elite wheels for not much more than the cost of the wolfrace ones (about £30) so might be worth giving them a call
Thanks a lot for that lads :) Worth the gamble at the £7 from ebay because it will stop her moaning about the vibing above 65/70 mph lol
Sorry, what rings are we talking about? I got distracted.. lol
ROFL I don't know which ones she would appreciate more :ph34r:
