Spacers - which ones
which wheel spacers are best? Hubcentric maybe??
I need some 20 or 25mm but not sure which. I have 18" antera 309's. The front are only 8" wide though. I believe these are ET35. The tyre size is 235/40/18.
Link are always brilliant ;)
Membership No 0780
INSURANCE GOOFA
I thought yours were the same type. I've mailed them as the site doesn't work :-/ they've not replied yet though. I also asked there advice on whether the 20 or 25mm would be better. Anyone got any ideas on this?
Pete, What is the correct bore size?
Membership No 0780
INSURANCE GOOFA
If you don't get no joy on the email he is a member on the 350z site and the orange zed site under mwtech
Thanks mate. Any idea on what size spacers I'll need? 8" wheel on fronts. Et35, I'm pretty sure the tyre size is 235/40/18. I'm wanting it to sit nicely like the back ones which are 10" and et35 with tyre size of 275/35/18
Membership No 0780
INSURANCE GOOFA
im not 100% but i think mine are ET38 on the front and i know i have 25mm spacers on and they are sitting nice and flush with 225 tyres on if that helps you
Based on a 8" wheel with a 35offset then either 20 or 25mm will be fine for the front.
There is a chance you could be at risk of a little rubbing with the 25mm spacer if car is lowered (depending on tyre brand, camber, ride height), its about as flush as you can get with stock arches. But if that concerns you then play it safe with the 20mm.
Edited by Yowser
What I don't want to do is get the 20mm and then still need them bringing out. I don't know the camber but the last tyres were worn on the inside if the helps. The tyres are fallen 452.
Any more advice mate?
Membership No 0780
INSURANCE GOOFA
