Android tablet gps help
Hi Guys, this one is for the teccies out there :) I`ve posted some pics of my Android tablet because I`m having problems getting a GPS signal, it has an external antenna, anyway after trying everything software wise I decided to take it apart and have a peek inside to see how it ticked, to my surprise the GPS circuit board doesnt connect to anything? is this strange or do the gps signals use bluetooth or similar, seems a bit strange to me
Strictly speaking it should be wired up/soldered/connected to the motherboard, I haven't heard of a gps unit using bluetooth to communicate with the motherboard before, but it is feasible to do so, lots of in-car GPS units are designed to connect to the device by infra-red or bluetooth for obvious reasons. For the board to be inside the tablet and not connected though, that's definitely odd!
CheerZ dude, thats what I thought? seems very very strange, time for a refund me thinks!!! I`ve joined an Android forum a few hours ago and no-one replied yet :(( this must be the only forum where peeps get a reply, thanks anyway, cheerZ
Daz
the gray wire to the left thats got ANT on the board that its solded to .. where does it go as that may be the wire to the Ant output board
That little green circuit board with the ANT written on it has no wires at all to it or from it, I have unscrewed it and it goes nowhere? i think the little grey wire you can see is just the solder joint? I think some dumb ass in the factory has forgotten to complete the curcuit :laugh:
Oh.... I see what you mean now, the other curcuit board?? that wire goes off to some sort of wire frame? will take a picture in a min :wink:
Edited by daZvert
ok thats some sort of internal ant ...
as the plastic lugs are there for it to be held in place when closed up ...
its your choice on what to do .. but it if was me i would be getting some more Screened wire and soldering up new wires to the output ant board .. so u can use your external ant if u have one ?
carnt quite make out but does the gray wire have 2 wires solded on the board or just one ...
outer wire is a screening inner wire is the ant ..
if u do what i said above u need to copy the way its wired on the external board ..
out plug being screen inner ant
Thanks Mark, so do you think that board with the grey wire and internal antenna is the gps output board? I do have an external antenna that came with the tablet it runs on 3/5volts so i need a feed for it aswell? I wondr why its not been connected? i bought it as advertised as gps enabled :thumbup1:
Edited by daZvert
yep 2 wires soldered,
yes that is part of the GPS ... but for some reasone the ANT socket board hasnt been connected ?
have u just tryed the satnav in the house or have u been outsite with it ... ?
as when your in house all satnavs are rubish
and yes most external ant need power as there fitted to the window screen they act as a signel booster
you will need some Phono lead thats screened ( RCA Wire )
are you handy with soldering iron and volt meter ..
use your contenuity ( spelling ) option on meter or unless u can see on the ant board
what conection is the screening side and Ant side and wire it in the same as on the main gps board
Ok, thats good to know its part of the gps, I`ve had the tablet semi built into my car and the gps is just searching all the time, its actually stuck in Japan where i assume it was last tested, I think when its connected to wi-fi it also find its position through the tinternet, thanks for all your help, i might find some pics of inside other tablets to see exacly where it need connecting, i have a soldering iron and probably some bits of antenna cable :wink:
