fao jefftt
jeff have you got any pic's of a mani swap
mainly the drivers side..do i need to deattatch the stearing rack completly?
thanks
Lol, couldnt have been further away from what you were after.
IIRC yours is an N/A ,you wont need to remove the steering rod. If you are fitting the japspeed manifolds, you will not be able to fit an O2 sensor in the hole supplied as it will then interfere with the steering column, even with the blank it scores the rod slightly.
sorry groover but i mght be being a bit dim here but how does the standard mani get out without droping the steering rod?
will it come out upwards
