De catting
My ZED was registered on the 30th April 1993. (UK spec TT manual)
It has cats fitted, and I have read a lot about de catting. What are the benifits of doing this, and can I get away without them?
Cheers all......
less backpressure, faster turbo spool up, basically, you're removing a huge lump of metal out of the exhaust system, not sure how it works with UK cars, but usually pre 1995 imports don't need any cats.
If you're using standard (oem) turbos then removing the cats will, as said, reduce the back pressure, but this can accelerate the oil seal failure......
If you've still got the oem exhaust it's better to replace this with a full bore exhaust because the cats are full bore
I'm sure JeffTT will come along and confirm all this !
Edited by TonyB
I am sure I have standard turbos, but the engine was re built some time ago before I got the car, I can tell you I have a mongoose exhaust system and 555 injectors.....lol
Just dont want to take cats off, if car then fails MOT.
as long as your engine is healthy, you shouldn't have any problems, i'd guess about half of us have de-cats (me included), and no problems with MOTs, (well not usually emissions anyways :) It's just the loss of back pressure can make a dodgy turbo oil seal more obvious, and doesn't help it, but if they are good you'll be fine... (my opinion anyways) :) HTH...
Great, yes that does, now all I need to do is find out what I need to do and I am on my way....lol
baz, decat it mate, your engine and tubs are easily good enough.
will give you hand if needed. can be an easy job or a total nightmare.
stu
stu
Thanks mate, I would love the help, call me when you have a mo..
