Not today but I did collect the zed this week from Powerzed...new rear main seal and clutch, new series 2 injectors and wiring loom, new fluids (engine, gearbox, diff), plenum deletes and Jimmer went the extra mile to make the plenum look like new. Plus a bunch more and it has made a world of a difference, the car runs so smooth now, the drive back was an absolute blast.
Huge props to Jimmer and Powerzed.
Mohsman ·
Not off a Z hence why I thought I'd post here.
It's off a 92 peugeot 205 1.8 diesel.
Done some research online and the consensus seems to be that the best way to test a coolant sensor is to measure the resistance with a multimeter.
Video of soime chap doing it here:
From what I can make out, I should be testing the resistance across the two pins on the back of the sensor.
When I took the sensor out the car and did this I got no result, zip. Aha I thought it's bust! Bought a new one but that does the same :blink:
After poking around a bit I found I can get a measurement if I touch one of the pins and the brass casing.
Does this sound right or are both my sensors bust?
When my multimeter leads are not in contact with anything they show the same as the top pic e.g. '1'
Pics of what I am doing here:
