rear washer
hi can anyone tell me if there is a washer bottle for the rear washwipe is it separate from the one under the bonnet some pointers please
Its the same washer bottle that controls them both. and the headlamp washers too on yours.
cheers for that but for some reason rear wiper works but not the washer also the front washer jets are rather patetic and headlight washers dont work at all screenwash is full anyone any ideas please
Check the filters (gauze) on the pumps.
is that the pump in the washer bottle if so how do i get to it can see the filler but thats all
drivers side in front of front wheel, I guess remove the front half of the arch liner, as said they'll probably be clogged up.
Yep the motors are there, turn you wheels to the left and undo the arch liner, if there is noise when pressing the rear wash button, either blocked at botttle or on tailgate. if no noise, then maybe loose connection or knackerd motor.
