protoj · 20 hours ago 20 hr
Hey Guys,
Just wanted to know if anyone knew of any good cheap and cheerful places to stay in or near inverness, scotland. Just looking for a place to stay for the nights and dont really wanna pay a fortune. Ill be sorting some stuff out there alone for a week next month!
Let me know if anyone knows of any good hotels or B&B.
Cheers!
Edited by Javelin
