clutch bleed help
No. 18 , not quite visible in pic - Clutch Master cylinder
http://www.300zx.co.uk/forums/showthread.php?t=26120
Small plastic resevoir with black cap.
2 bleed points, one by the Hicas solenoid above drivers headlight, and the other on the slave cylinder on the gearbox. Ripping out all that excess metal piping and replacing with a single braided line from Master cylinder to Slave cylinder makes bleeding a lot easier.
Edited by Yowser
Amen to that :cool3:
Dont know if you got the system bled but I used to use a 12 v washer pump to back bleed the system from the slave cylinder up, used to work a treat.
Cheers John
