manual conversion wiring??
well im reading up on my manual conversion and my brother has already started on a few bits for me, Ive got the write up off of twin turbo.net but it hasnt got any off the wiring steps in?? does anyone have a write up on the wiring please and what needs to be done
thanks craig
nice one thanks Graham, yes on the mend still hurts to laugh but i look a little more human now, still dont feel it though lol
i dont seem to have pics on that link is it just my laptop??
No pics lol, but to start with you need to peel back the drivers arch liner an join the wires for the starter relay to get it started, the other alternative is to wire to a switch on the clutch pedal for start.
There are a couple of pics somewhere for the reverse and neutral, will try and dig them out. The best way for the neutral switch is at the ECU, give me ten mins and i will see what i can do.
Edited by groover
Just put this together, it should help and answer a few questions
Nice one mate, that's tomorrow's job sorted :)
Just a pointer.......the write up says to use pin 48 for the nuetral switch but it should be 44.:wink:
noted. Cheers mate.
Thats the yanks for you Daz, but i think your right :winkiss:
The beeper (grey box) is under the dash above where the clutch is/would be
Edited by groover
Bypass the box and join the wires for the reverse. Im doing mine soon, will try and take some pics and wiring colours
I never did suss out the correct connections for the reverse lights even after Jeff put some pics up of the wires i needed to connect to , in the end i thought sod it and didn,t bother with them and are now using them as fog lights with red led bulbs in but the really odd thing is that the reverse switch isn,t connected but when i put it in reverse the reversing bong starts :confused1::confused1::confused1:
