NA carbon canister
afternoon guys.
a quick question what would happen if i remove these two vacuum pipes from the carbon canister and blank them off at the intake pipe and the throttle body?
the reason why im asking is that when i swapped my injectors im having a couple of running issues after i removed these vac pipes.
when warm it can take a couple of turns of the engine to start, it will run rough for a few seconds then it seems to clear and run ok, (pointing me to a fuelling issue?) generally after a hard drive.
as i havent done a complete carbon canister removal would this have caused the problems.
i have been round the connectors and they all seem ok as i cleaned them when i had the plenum off... or do you reckon its related to something else??
Edited by hellraiser
