speedo
ive got a problem with my zx since i bought it the spedo is well out spedo reads 22mph=30mpg
45mph=70mp
and worse of all when i first got the car i though my god 70ish feals rather fast in this car
75mph=116mph
how do you know this??? think i have the same problem.
Does it have a facia put on or a kmh to mph converter (Possibly miswired) ?
A quick conversion has 116kmh = ~73 mph that may be may be a coincidence though...
I imagine if none of the above, then a faulty sender unit but I am only guessing.
Best way to test is compare to your sat nav CoolQ.
Edited by Bartflaster
when i reached 75mph and was passing the odd car as if they where stoped i then put a tom tom in whitch told me the true speed
just dont want to drive around with a sat nav all the time would prefer the spedo to work really no idea the spedo in mph only gose to 110
Sayers had the same problem. He had kph clocks with a mph face.
Uk clocks sorted it.
It seems like a 110mph face/clock has been put on instead of a 180,so not giving a true reading from the dial face.
or a manual conversion with the wrong speedo cog left in !
well if it helps anybody ( and depending on rear connection configuration ) i now have a multitude of dash clusters, perhaps the 180 KMH jap faced dial with my converter could transplant into someones cluster without too much trouble, as ever welcome to bell me on 07929159828
Neil
Hi bud, could you explain this one? Just i had a conversion done and was wondering what has to be done on the speedo?
[sIGPIC][/sIGPIC]
I had a manual conversion done on my Auto TT and I they put an NA box on it..... that has a different speedo drive cog apparently so when the speedo says I'm doing 70 mph in fifth I'm actually doing 85mph
Other gears are out and reading under as well
Just waiting for the correct drive cog to be fitted
It's got B all to do with the Kph to Mph converter
