Exhaust sensors
Hi, i'm fitting my new exhaust system tomorrow so had a look under the car today and noticed that the decats dont have the fittings for the 2nd set of sensors (after the cats)I'm guessing the car will run ok without these fitted? and there will be no warning lights permanently on?
It,ll be fine bud , they,re cat overheat sensors , i just cut the sensor off and tucked the wires out of the way , if you want to remove and disconnect them properly you have to remove the centre consol as the little box these plug into is under it . HTH
Great help, thanks.
