HDD problems?
Hi,
Doing a backup and it says it can't read some of the drive. I've had no errors using XP in normal usage, just backing up.
Can anyone suggest a good hard drive diagnostics to run to check my drives?
Vijay
Have you tried running chkdisk ?
Run it first without telling it to fix so that you guage what the problem is....
Hi Tony,
Just ran it and it found some segmants unreadable.
Cheers. How do I do that?
Just read a few pages from Google and it suggests the HDD is failing??
It could be - see how many bad sectors you've got and take it from there... take a back up now though, a drive can go pretty quickly if it's failing.
If the sector is physically damaged, it will be marked as bad - ok if it's just the odd one, but not good if it's the beginning of the end!
Taken a back up but there's a couple of files (pictures) it can't access.
Ran chkdsk/f and it booted back up into windows without stopping/reporting any errors. Chkdsk is still saying there's errors :(
Is there anything I can do or should I replace the drive?
Vijay
