smoke advice
hi all got a little issue with smoking on the zed, it started off if the car was left ticking over for around 10 mins it would start to smoke through the drivers exhaust, when i had the car at zedworld back in october jeff suggested replacing pcv valves as that was prob the cause (and the passenger pcv valve was pretty oiled up at the time) so anyway i have now replaced the pcv valves and hoses but i have noticed after a very short run (4 miles to work) the drivers side is smoking quite heavilly on tickover (which it never did before), i know it takes 500ish miles to clear oily residue from replacing pcv's and turbos were done 8000 miles ago by previous owner could there be something more serious wrong or is what i'm getting normal?
cheers all
Mine is exactly the same mate, I've not done the 500 miles yet. Is yours smoking on boost as well?
no just on tickover but is worse than it was before i did the pcv valves and pipes
