Brake options
What options are there for upgrading the front calipers (apart from brand new 6/8 pots) Heard of people using 350Z/GTR's etc.
Mine's seems to be oversized discs with the standard calipers and although they work great you can clearly see the part of the disc that the caliper isn't working on :/
Skyline R33/R34GTR fronts are popular.
They're 330mm Brembo 4 pots. R33 straight bolt on, R34 need the hub carriers drilled out to 14mm.
Much bigger pad area than the stock Akebono callipers, pretty good upgrade.
Cheers for that John I'm gonna get a measure at my caliper/discs that or on just now because there seems to be very little clearance from the claiper to my rim. I'm hoping it's because my original calipers have been spaced out to fit the oversized discs!
Evo Brembo calipers are a good choice too, slightly bigger than GTR calipers and can be found on the bay at very reasonable prices... sometimes. New seals and dust covers are £115 delivered, 350Z track discs and pads, then you are ready to go. (+ brake fluid)
Alz.
