- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Ok, I have all the symptoms of temp sensor problem.
Car starts from cold as normal. Heater used to come on about the same time as the guage started moving off the cold but now doesn't come on at all. Engine runs rich (smells of petrol and has hestition when warm). Temperature guage stays at normal for a while then shoots up towards max before I kill the engine. Heater is still cold.
Occasionally the heater has kicked for a few minutes and then gone cold so problem is intermittant
All what I'd expect if sensor is kaput.
Searching through previous posts the black sensor is for the guage, the yellow one is for the ECU. I have taken the connector off the yellow one and cleaned it a bit (it was fairly clean anyway) and its still the same.
Do these sensors fail often or is it usually the connectors need cleaning? Could it be anything else?
