if anybody can help ,,
My dad has a 54plate c3 1.4 hdi but he want front fogs fitted into the plastic blanks! The question is: will the wires be already installed? Also will it just need a relay fitted? Or will it need to go to a Citroen main dealer & be plugged in to get them to work through the ECU?
the wires should allready be there. and i think you will just need the switch and relay like you said. they normally use the same loom for all their cars as it cuts on cost just to make 1 as standard. lol
i mean all c3's should have the same loom not all citroens. lol
Ok thanks so u don't think I need to send him to citroen to be put on ecu computer thingy?
Ouch!!!
Ok I'll pop the blanks off tomorrow & see if I can find the wires ... Then check the fuse box for a place to fit relay then rig a switch up as his stalk only has rear fogs on it !
My other half has a honda jazz and I put an uprated bumper with fogs on, Every thing was there easy job.
I would say just have a look see if you can find some loose wires..
Weasel if you get stuck, ask on this forum mate, http://www.frenchcarforum.co.uk/ its ran by my mate jim, forum name Citrojim, he is a citroen god and will let you know for definite.
That's wicked thanks .. Very helpful that's why I love this group of 300zx owners :punk:
