Area below scuttle panel
Went to replace my scuttle panels at the weekend and found below them was quite muddy with a few leaves mixed in
Do you think i could flush it out with a hose,would the drain holes be big enough
Jim
I wouldn't go made with the hose, you may have a blocked drain. I would remove all debris by hand and gently flush with water.
Al.
Hi Jim, as Alan said no water matey just dig out what you can first then maybe use some wire or something small to unblock the drain matey :thumbup1:
Cheers guys
the drains under the scuttle are very large and go straight into the wings, however the wiper motor lives under there, i have jet washed mine before but you need to make sure it doesn't flood, i put a plastic bag over the motor as well
