Cost of fitting DW total hicas eliminator kit
Roughly how much should I expect to pay for this? The fitting, I mean.
couple of hours, max.
Depends on if your wanting the pipes removed or just cut back
Nice one Shrek. Thought it was a bigger job than that. Anything else I should look at getting done at the same time?
I had to remove the rear hubs on mine to press out the Hicas ball joints...so whilst they were off I changed all the bushes on the rear hubs for poly ones. Worth doing. You'll really struggle to get the Hicas ball joints to budge without a press if they're the originals.
Mmm.. rear hub bush removal can be tricky if you have not done them before and if using a press both rear wishbones need removing, even a garage would charge 3 to 4 hours expect around
Jeff TT
