hicas an few other q's
hi all,
i have a light on saying "hicas" i hear its the 4 wheel stearing, any ideas what it would be an what do i have to do, many thanks,
also whats the switch top right hand side of auto gear leaver, the power an hold one,
thanks in advance
Check your Power Steering Fluid level. The same fluid is used for power steering and the HICAS system.
not a problem. it's the small round pot on the drivers side of the engine. (Just incase you didnt know ;) )
hi all,
thanks in advance
I agree, check your power steering fluid. And the button on the side of the auto shifter:
Hold: pulls off in 2nd gear (good for wet or icy conditions) and holds the box in higher gear for longer i believe so it wont change down so quickly if you put your foot down.
Power: what it says on the tin.
As an aside you also have an O/D button on the side of the auto gear stick you will feel quite a difference with it depressed or not, the box changes at higher rpm and she feels like a different beast.
thought ide add as ive seem a few people talk about this now, but my speedo dont work either, would my first place to start be getting a new speed sensor
