blower motor rewire help
hi
i've been having no end of problem with my blower motor not running. i've changed the relay and the amp but none of these seemed to have made a change to the situation. i tested the motor in the past wired directly to the a battery and it worked fine. i can only assume that there is either a positive or negative power supply issue. i have to make a temporary fix till the weather changes, just in case i have to make an emergency trip anywhere.
I have read that the power can be by-passed and a switch can be put in place, can anyone sketch me a quick diagram outlining where the wires are to go on the plug going to the motor and which ones they are. i may find that there is a loose negative somewhere and only have to re-make that one but just in case i have to do the lot i need to know which wire goes where.
The rest of the system works and i can hear the vents and servos working when selections are made. This is for the auto climate control system and not the manual type on a 91 N/A 300zx. Thanks in advance for any help.
:confused1:
No posts to show
