Hushhhhhhhh ing noise
I have a airy gassy sound when I drive. At first I thought it was my turbos becasue it gets louder as I accelerate.
However, it only does it in 4th gear. I have tried it in 1st, 2nd 3rd and 5th and all dont make a sound. Its just 4th gear?
I dont think its the turbos, cos I can accelerate and the sound gets louder, I then let off, let the turbo spool down, and if I accelerate hard again, the noise goes straight back to how it was, before the turbos have time to spool up.
The sound cold also be compaired to when you shake a light bulb and you get a gassy rattle. Its like that but quite loud.
Please any ideas?
Just am idea - check the plastic 'boot' that surrounds the gear knob (ooer) ir may have come away and ahen you shift it becomes more boticeable
Glen
also - further to that, it sounds like detonation, I occasionally get the same sort of noise and its usually in 4th gear under load (ie 45mph, up a hill(.
I only happens briefly then goes away... not the'marbles dropped into an empty can' noise tho frown.gif
Glen
Apaaling spelling but i can see two keyboards:_
it could be the rubber around the gearbox and it also could be a brearing under the selector.
I have been meaning to do mine but havent had a chance.
