Yeah got this in mine although tho dome festoon bulb connector is crap and doesn't fit right! Ended up doing away with the dummy bulb connector and just soldering the + and - direct to the original light fitments. Very bright tho and makes a great replacement! Whole interior lights up!
yep replaced mine too with this, the dummy bulb needs to be compressed with a bit force to fit, did mine in couple of mins without the need to solder
You can get them for half that price from HK, you wait a little longer, but thats where the seller would have got them in the first place. The festoon fitting needs to be 31mm unless you are going to be hard wiring.
