protoj · Tuesday at 18:48 4 days
Beam me up scotty!
Ive got steam (water leak)venting from somewhere on the left hand side (standing in front of car) of engine. I am loosing coolant and just wondered if anyone has any ideas? The heads are fine it appears to be coming from quite low. Compression is A1 on all six.
Live long and prosper (unlike my engine)
