  1. Tap the 3-dot menu (ā‹®) in the top-right corner of the browser.
Whats code 13 mean?
hey reset my ECU last nite and its giving me code 13 after a bad bad drive home from work, whats code 13?
thanks
Its gone into safty mode, could be a faulty dett sensor
ok thanks guys, just wipd it out, fairly corroded terminals, had this on my old 325.pain in arse, something so small, can make it seem like you head has a big hole in it or sumin. wire brushed em, scraped with pik,put some solder flux on em, and washed em wiv vineger, hopefully this will help until i can get a new one in, would this also put the car in safety boost?
thanks guys
oh why did my link post wrong i was looking at the right page???
brake bleeding lol, just bin for a drive weathers terrible here, but good news, seems to have sorted the bogging, also new theory.. if theres no water for it to sense, would it malfunction, could be a good indicator of my water getting low.lol.not really funny. also before i reset the ecu, i was only getting 6psi wiv No fault codes after resetting the ecu got fault code 13,ECT, which would put it in safety boost mode? would i have to reset the ECU to put it in normal mode? or will it detect the fix.(temp fix) or should i star searching for boost leaks?
thanks
