stage 1 ecu chip -
is there any point in getting this?
http://cgi.ebay.co.uk/NISSAN-300ZX-STAGE-1-ECU-CHIP-Z32-VG30DE-NA-FAIRLADY-Z-/230535203929?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35acf80c59
my car (is a frankenstine mess) its an NA shell with a TT uk engine and a jap ecu, im trying to run higher boost but suffering from a minor misfire, iv checked for a boost leak, replaced the fuel filter and stuck some redex in and that solved quite alot, the misfire has nearly gone but the boost is weird, so replacing the plugs and doing an oil change tonight.. is there any point in buying this chip? will it help?
I do have a chipped ecu for sale and correct me if im wrong but the link you have posted is to an NA chip which is no good for you as your running a TT engine?
Craig
Yes mines tt, how much for yours? What is it set up for?
Its a JWT chipped ecu, the car it came off had the following mods stage 1 hybrid turbos, straight through exhaust, Blitz filter and apexi AVCR. The ecu can be remapped easily if needed, looking for £130+p&p
Craig
Edited by ZX-TT
I'm runnin standard turbos... I think I'll just go for the tt wolf chip, wouldn't wanna push them too far
Which ever chip you get you will have to get mapped to your current set up, someone may be able to confirm this for me but , it would probably be cheaper to buy mine and have remapped as appose to getting your ecu socketed and then mapped?
anyone?
How are these chips fitted are they plug and play or are the fitted then soldered and re programed:stupid:
Craigs will just plug in and play. It will be a base map for a stage one :)
