very odd
ive got a 92 jap tt wen i was going 2 work the steering went heavy ,speedo went off and the hicas light came on.
wen i got 2 work i stoped and re stareted it hicas went out but power started flashing.
all night this has been going on 1 min its sweet then no speedo and heavy steering????
I pluged it in 2 consult but it never brought any real probs up any clues guys please ??? Chers
Must be an auto since you mention the power light flashing
Either;
There is a problem with the road speed sensor
There is a problem with the speedo head
There is a problem with the wiring from the speed sensor to the clocks
I would put money down that if you did an Auto tranny diag it would come up with a speed sensor failure.
All three systems (speedo, power steering, auto box) are running off that one sensor...
Az
Ooh almost forgot, the power light flashing like that means that the auto ECU has a stored fault code/fault at that point in time.. I *think* the number of flashes means something, but it *doesn't* correspond to the table that goes with the auto diagnostic (which can be found on http://www.twinturbo.net)
[This message has been edited by aaronjb (edited 29-11-2001).]
My speedo stopped working, but it didnt effect the powersteering or the HICAS.
More than likely its the Speed sensor.
Doesnt the ignition light flash when the speed sensor stops working?
Also check the curise control, I dont think it will work if the speed sensor stops working. My one still worked when my dial packed in, which meant the speed sensor was still sending information just my dial stopped displaying.
Does your odemeter (Trip counter) still work?
Stuart
cheers 4 the help guys the z is auto and yes the trip has stopped.
the DTC results said vhcl-speed sen-mtr
& throttle posi sen.
speed sensor is £115 minus trade plus vat it looks intresting 2 fit aswell NOT????
If you've got a speedo convertor on there, just try unwiring the convertor temporarily.. It's worth a try and could save you mega.. they've been known to go wrong (mine had)...
Az
