PCV valves
The car i bought is smoking a bit. I thought it was the turbos, but reading on here i want to change the PCV valves first.
Where can i get them from, and how hard are they to fit??
Nissan part only so Mike at MJP in the traders section - be sure to replace the hoses too as these get hard & brittle with age. Not too bad a job. Plenty of write ups on this :)
just make sure you have a long extension bar for your ratchet from memory the one side you need to have ratchet at rear of the engine to loosen valve
Edit last post, just reading the link.
Cheers mate.
