Air con belt size with underdrive pulley
Can anyone tell me the length of air con belt required for an NA 1990 with an unorthodox underdrive pulley, did a search but not found the info needed :cool2:
111 sd-13-10 nissan a1920-f6501 4pk965 >cr
this is how its worded on the belt
For anyone searching for the info the length is 905mm or 36.5 inches, thanks all, Richard.
I have a Gates Micro V KO40365 here if anyone wants one.
Unused:cool3:
Cos I dont do aircon:whistling:
Unused:cool3:
And neither do I:thumbup1:
I enjoy having air con in my everyday bus !! just to add the closest I could find was a QH 925mm belt which fitted a treat.
You have fitted a QH part to your ZED:ohmy::gun_bandana:
Quinton and hazel,that world leader in quality aftermarket car parts Lol.I used to use Borg and Beck clutches years ago until Q & H took them over,wouldnt fit one of those to drive it to the scrappy :scared:
Its only a belt, I did ideally want to fit a gates belt but had to get it sorted on the day and its the only one I could find locally, the idler pulley broke before Christmas and its taken me this long to get it sorted !! lovely cold air again just in time for winter.
The one i gave you dimensions from ,was to use with an idler pulley
Thanks but that one is for a car fitted with a standard crank pulley, mine has an underdrive pulley and requires a smaller belt, yours was 965mm and I needed 925mm. The idler pulley is the part you adjust to tension the belt, the bearing broke up on mine and snapped the belt hence both needed replacing :thumbup:
Got me thinking i had brought the wrong spare . :sweatdrop:
