Major Engine Oil Leak Help
I have a major oil leak from the crank seal. From visual checking it seems its coming from where the gear box meets the engine at the bell housing. This was probably due to me putting in an automatic line controller for the automatic gear box..
Where do I go to fix this? Anyone in London or Greater London that can advice where I can go to fix it or help?
:confused1::confused1::confused1:
If its just the rear crank seal.Luke from ZCenter sells them,not alot of money.Any competent garage that fits clutches can do it.Around £20 for the seal and about £200 labour.
mine is leaking too, £26.92 i think was the price from mike at MJP on here, which is a good price, but still silly money for an oil seal tbh, it's a gearbox out, clutch and flywheel and it's there, will be doing mine soon, getting about 5 drips a night when parked up...
cost me £296 total have to admit was gutted as had clutch done the year before and to be honest the garage should advise changing it then would have saved bucks that way.
Yep Thats Pretty Reasonable To A Student Like Myself Too!...Where abouts did you get it done? Any Contact Numbers Or Address?
Does Anyone Know A Guy Named 'Mickey B'...He's Worked on This Zed Before..Did a Cracking Job When My Elder Brother Had the Car, Unfortunately Lost his details..
i ment rather than it costing me 600 + clutch, if garage said shall we change it whislt doing clutch,as all off would have saved 296
Are you sure its not leaking from the sump at that point, it can look very much like crank seal
Not Quite Sure To Be Honest...But I Know The Damned Gear Box Does Need Coming Off...The AutoBox is on its way aswell..I've booked in with the zedworld on the 24th of this month so will see how it goes..I've always wanted a manual conversion done...Any tips or advice...and any idea how much roughly I'd be looking at?
